Hi All,
I saw an ad with a used HDR-1 at a price of 200 Euros and the gadget freak in me immediatly woke up..
I have a Beovision 3-32 without STB controller card and I have an AppleTV and a DTV box from Sagem to watch digital TV.
Since I would like to control those boxes too with my BEO4 I thought the HDR-1 might be a solution that also add HDD recording to the mix.
So my questions are:
1. Is it possible to control 2 non B&O items via the built in STB in HDR-1 just as if I had a STB card in my BV3 ? And is it "upgradeable" to handle AppleTV? The price for this used HDR-1 is almost the same as buying a STB card to the BV3 or a separate Lintronic box..
What would you suggest is the best solution, HDR-1 STB, BV3 built in STB card or Lintronic?
2. If I understand correctly, the HDD is only 80 GB which is not much these days, can it be changed to a bigger one without any problems? And can I somehow get the content out from the disc (whithout dis-assemble the whole box)
3. Is there any functionality to use the HDR-1 as a digital box? card reader etc?
Let me know what you think about HDR-1, is it worth buying?
Thanks!
/Peter
