So I bought a used 4004 TT with 7 Pin connector and my BM 3000-2 has 5 Pin connections.
Went to eBay and was searching for adapter/converter and saw an ad for a 5 pin to RCA and in his ad he adds that if you have 7 Pin connector you can....And I not sure what he is saying becasue of language issues, but thought he might be saying you can exclude pins 6 and 7 and then plug it in. Here are his exact words "If do you have a 7 Pol DIN male plug ,usually are pin 6+7 screwed, it's can be removed."
Was wondering if anyone can add or clarify this.
