Hi all
Had some of these for some time just got round to re mains wiring em , now done.
Bootred 'em up today one works one doesn't - checked the output of the transformer and it appears to be working - i therefore assume the problem is the standby board - anyone any ideas - the units worked about 2 monthsa ago when first acquired.
When rewiring all i touched were the transformers ie remove from unit rewire replace!
My idea is to transfer units from the working unit one at a time to check and id the faulty board then work on that, however, other ideas gladly welcomed!
salut a un p*ssed off stotty1111
salut
tony
I always try to operate using/following the KISS principle -- Keep it simple stupid!
