1st March February 2012
Latest post 06-28-2007 6:51 AM by Alex. 15 replies.
06-26-2007 2:28 AM
Beonut
- Joined on 04-17-2007
- Essex, UK
- Posts 89
Do you have an sp/dif cable beteen the dvd and the bs3? you need this to get dd5.1 or DTS, otherwise you will just be getting dolby prologic II. Have you checked on the bs3 what sound codec you are getting? to do this play a dvd then press - menu, options, sound, sound system and you will see the input sound and the output sound displayed. Regards Peter
My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
Oasis
- Joined on 05-13-2007
- Posts 109
What's a sp/dif cable? I think the BC2 is connected to the BS3 via masterlink cable... The sound system display DTS 5.1 but no sound is coming out... Hmm....
Emmanuel92
- Joined on 02-14-2007
- Paris
- Posts 2,032
If the dolby digital works, the SPDIF cable is ok. Does the system display Dolby Digital in the sound menu ?
Curious: the active sound system is DTS, so the BS3 has "understood" that the stream is DTS...
Quoi de mieux qu'un BeoLab 2 ? 2 BeoLab 2 !
Beonut
- Essex, UK
- Posts 89
Sounds a bit silly but are the speakers switched on? In my setup when I bring on my DVD1 the bs3 only brings on the center channel (ie speaker 1) apparently this is a prob with the dvd1 as i have one of the first versions. I then need to press speaker 5 to manually bring on all the speakers. Regards Peter
Oasis
- Posts 109
Ok...so a bit of a correction... When I select DTS...the sound system input is "mono/stereo" and output is still "Dolby prologic IIx Movie speaker 5" but no sound....but when I select dolby digital the surround sound works fine...and I'm sure the speakers are on coz the green light on my BL5s are on and I have simply changed the audio by pressing the red button during playback...SO THIS IS THE PROBLEM! SPOT ON!!!! Regarding the sp/dif cable....I'm not sure whether it's there or not since everything was installed by B&O and hidden away...but I assumed it would be silly for them to not install that as well...No wonder the surround sound is not sounding as good as I thought...I'll let my installer know ASAP!
soundproof
- Joined on 04-16-2007
- Posts 2,340
And make certain that your S/PDIF Coaxial Digital Audio cable is 75Ohms, with RCA at both ends.
Beonut
- Essex, UK
- Posts 89
On the same AV port as the Scart or other video inputs are connected to for the BC2. regards Peter
Oasis
- Posts 109
Thanks for everyone's response...I'll try to get this sorted asap... This might be a stupid question...I assume that Dolby Digital will give a better sound quality that dolby prologic...and DTS should be better than Dolby Digital (I know this is controversial to some)...
Beonut
- Essex, UK
- Posts 89
And if you either connect a Playstation 3 or a Blu-ray player by hdmi to the BS3 and play a blu-ray movie you will get Uncompressed PCM 5.1 sound which is even better (much much better) than the DTS you get from your DVD . Regards peter
Alex
- Bath & Cardiff, UK
- Posts 2,990
Beonut:And if you either connect a Playstation 3 or a Blu-ray player by hdmi to the BS3 and play a blu-ray movie you will get Uncompressed PCM 5.1 sound which is even better (much much better) than the DTS you get from your DVD . Regards peter
Yes, it's pretty jaw droppingly good!
You'll also be all set for all the future formats, such as 7.1 surround sound etc.. (where you have extra speakers behind you).
Weekly top artists:
Page 1 of 1 (16 items)
