Problem solved. Transposed two numbers............
Might disable the function now (as no-one would try to steal a CRT television weighing half a ton these days!) Or might write the codes down somewhere and not rely on my no longer infallible memory!
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
