Hello,
I am intending to combine Beovision 10 with an older two-way Beosystem 2300, a Beogram 6500, a Beoport and link setting with Beolab 3500.
The Beosystem has a Datalink splitter for the Beogram and will be connected via Beolink Converter 1611 to the Beovision.
I have two questions:
1. Will Beosystem/Beogram and Beoport work in this configuration and also in link-setting because the older components show "Phono" in their display whereas the newer ones "Netradio" and the older Beosystem does not accept Beoport, but I hope the Beovision does.
2. I have also a Beolink 7000 and do not want to loose the two-way-option of the Beosystem. Is there an option to program that the Beosystem works with the Beovision and still keeps its two-way?
Thanks a lot for answering my questions.
Andreas
