Dear chums
Advice please! Got a Beocenter 1 with dolby module and when turned on via the sat button on Beo4 (it is fed by a Topfield freeview receiver) I get a series of rapid clicks coming from the loudspeakers for about 10-15 seconds. Then it passes. It's not the end of the world but it takes away the delight of turning the unit on! Anyone got any ideas/ troubleshooting ideas?!!
Thanks in advance
Kind regards
Jonarhan
Hi
Do you get the clicks if you switch the BeoCenter on with either DVD or TV command?
Is there a setting in the Topfield box for adjusting sound output via scart or similar?
Opman
Hi Opman
It ckicks when DVD firing up too for only 10-15 secs or so. I think I might get another extension cable as then I removed and replaced the plug for the Topfield, it made the extension cable red light flicker about and make a rather wier buzzing noise! Fingers crossed.
Mine makes one "tick" sound from the loudspeakers each time i fire up a dvd... always has done it :(
There is a mod` for this.See your dealer.
