When I turn on my BS5 (N.Radio or N. Music) the sound level is around 50, eventhough the sound volume is set to around 30 on the TV sound menu ?
Does anybody have same issue or know were to set the sound control on the BS5 ?
Thanks.
Use lever to activate MODE.
Use wheel to select SETTINGS. Press <<.
Use wheel to select VOLUME. Press <<.
Use wheel to choose volume level. Press GO.
That works fine for me.
