Hi...
I am new to this site. I bought a B&O Beocentre 9000 recently and love it. I have been searching the net for the Beogram 9000...but am having difficulty finding one. Are they a rare item?...can I use another Beogram in it's place...and if so, what is the best model to go with. Thanks and I appreciate any answers.
Steve
Personally, I don't believe that the Beogram 9000 is a good cosmetic match so I would look at others.
You can use any turntable that does NOT have a built in RIAA pre-amp. See here
http://www.beoworld.org/article_view.asp?id=67
Regards Graham
Thanks for the reply and input. As I mentioned, I am new to being a B & O owner...what Beogram would you recommend at the best to go along with my beocentre 9000?
If you fancy a tangential deck then the best value for money and a good cosmetic match would be a Beogram 3000 or 3300.
Ensure that the stylus/cartridge is good (Should have MMC4 ) because they are hellish expensive to replace.
