Looks like somone else has designed a bracket then - nice one Paul.
The one that I once owned was much more substantial than this version as it was made from good quality sheet steel and required the removal of 3 screws form the front of the beocenter to attach it in situ. A real nightmare to do by myself as the beocenters are very heavy and not the easiest thing to manipulate when they are only half held together- but I eventually managed!
Definately NOT an official B&O product BTW - I previously mentioned the 35 degree angle which is about the maximum angle these beocenters will accept and still be able top play CD's. I believe the 9300? has a clamping mechanism to hold the CD in place which would in theory allow you to hang these totally vertically.
Chris.
