I am having problems locating this plug-in for Itunes. Having searching the Internet for hours I kinda gving up!
Help! Can anyone tell me where I can locate the MAC: iTunes: BeoSound 6 plug-in?
there was a recent post advising to use Max OSX's Finder for managing the BeoSound 2 because the BS2/iTunes interface broke with the arrival of iTunes 9 ... perhaps you can/should use the same technique ?
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
I understand the technique as described http://forum.beoworld.org/forums/p/30941/248278.aspx#248278
But I require the BEOSOUND 6 Device to be seen within Itunes, which is possiable with the iTunes: BeoSound 6 plug-in
Thank's
