With pleasure...
You have installed a Beolink Passive to the link room (with 2 passive speakers of course).
You set your BV SETTING FOR  modulator-> ON (it is in the menu tuning settings->link frequency-> modulator)
You connect the LINK TV OUT of the BV to the TV IN of your other non B&O TV.(with a good quality sat cable)
You select a link frequency to the BV (on a frequency not occupied by a TV station)(for example 895)
You manually search this specific frequency to the non B&O TV .
You store the freqency.(at that time you see ''snow'')
You press DTV, or DVD on the IR of the Passive with the BEO4....and TADAAAAAAAAAAA
YOU WATCH IT. AND YOU USE BEO4 as normal.
Note: The sound will come both on Passive speakers and of course to the speaker of your  non B&O TV, but it will be STEREO in passive speakers and MONO to the speaker  of your non B&O TV.(small problem, you just use the passive speakers)
Hope this helps...Any questions are welcome....
Dimitris
