Dear Forum-members,
I hope you can support me with my problem. Yesterday we've had a movienight at home. I've invited some friends.
The second dvd was playing and after a while in a kissing-scene the player stopt playing! I thought it will go to another point and will play further. But ist Just keeped spinning! A rattling sound was coming from the player and i had to shut the tv off. After that i tried it with alcohol and now it's playing for about half an hour and then it automatically stops as mentioned in the Title. When i looked at the dvd, it was full of scratches, now i think it's my fault. Why didn't i look at it before.
Maybe you have some suggestions for me to solve the problem! A new unit is a bit expensive i think.
With Kind regards,
Michel Gallus
