Latest post 12-29-2009 4:44 AM by j0hnbarker. 1 replies.
Page 1 of 1 (2 items)
  • 12-29-2009 12:51 AM
    Beosound 2 - battery replacement
    given that BS2 is likely to have a secondary cell; does it require a replacement after a gap of 3 years or so.
    the problem that i am facing is that my player does not retain charge.
    despite the player been on the docking station for ~ 2-3 hrs the blinking green light would not return to a constant green.
    given the above is it conclusive that the battery needs a replacement - if yes can you please indicate approx charges towards getting it serviced from B&o
  • 12-29-2009 4:44 AM In reply to
    Re: Beosound 2 - battery replacement
    I looked into this about eight weeks ago. Replacement batteries (minus fitting) were £67 each!
    Ouch!
