Latest post 12-22-2009 7:55 AM by spezializten. 2 replies.
Page 1 of 1 (3 items)
  • 12-21-2009 7:43 AM
    Beovision 8-40 together with BeoLink Active
    Hi all!
    Is it possible to have for example an audio source connected to a Beovision 8-40 (V.AUX) and then distribute it to a BeoLink Active?
    Or does this require an AudioMaster or a B&O linkroom TV?
  • 12-21-2009 10:47 AM In reply to
    Re: Beovision 8-40 together with BeoLink Active
    should work.
    I have an iPod Touch on V.aux2 and this can be distributed over ML. The iPod is connected via Apple Composite Cable.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 12-22-2009 7:55 AM In reply to
    and you don't have any AudioMaster connected in the masterlink?
    I had a BV 8-40 for test and I just tried the built in DVB-C from a BeoLink Active. It activated the speakers and then turned them off?
