Thanks for all your helps so far, I am getting there slowly with my setup.
I acquired a BeoLink Pc2 box to hook up my mac, I have connected everything up and I am still struggling to get the damn thing to work with my setup. To simplify things I have removed one Tv from the system and below is a list of my connected equipment.
Room 1: Beo Overture - Record Player Connected to Aux - Set to Audio Option 2
Room 2: Beocentre 6-23 TV - Set to Video Master 2
Room 3: Beolink PC2 No IR eye connected- Set to every option under the sun and nothing works.
So far I have had limited success to get things working the only way I can get repeated success is through Linkplayer, setting the Beo PC2 to option 0, this way I can play N.Music on the speakers connected to the TV but the overture Room refuses to play. B-M Link refuses to do anything, however I have read that there are issues with ITunes 9. My Mac is running Leopard 10.5.X - ITunes 9.
I have tried just about every option under the sun to get this working, and there are some very strange things happening, such as when I press N.Music on the TV the overture switches on and displays tape2 but no sound is output from the speakers.
When I press N.Radio on the TV or the Overture the record player on the Overture starts and the record plays through Masterlink, which is not ideal.
I have even tried B&Os software on a Virtual PC, I did manage to get both N.Radio and N.Music playing on both the TV and the Overture at the same time however I think this was a fluke as I have not been able to reproduce this.
Can anyone suggest any settings please.
Thanks,
Nic
