Latest post 11-28-2009 9:19 AM by TWG. 4 replies.
Page 1 of 1 (5 items)
  • 11-28-2009 4:05 AM
    Surround Sound Amplifiers (processors) for use with B&O speakers
    I have...
    A 9000 CD player, 2 x Lab4500 wall mounted panels (front speakers), 2 x Lab 4000 (back speakers) and a lab 2
    They are all plugged into an Avant TV that is starting to fail... So I am looking at options!!!
    The best B&O options are to buy either a Vision 10 or 7-40 to replace the Avant - a simple swap over...
    The other option is to hook everything into a decent Surround Sound amplifier that can support active speakers...
    DOES ANYONE KNOW WHICH MANUFACTURERS DO THIS? I understand DENON have variable line out for each channel?
    One issue I am aware of is that the Lab 2 needs a power line to switch it on (it does not sense the line in signal) - Is this currect?
     Also - As the Lab 4500's only have link sockets I assume I will need to convert them to phono (RCA)...
    Any ideas or advice would be most welcome...
  • 11-28-2009 4:11 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: Surround Sound Amplifiers (processors) for use with B&O speakers
    Welcome to BeoWorld !
    Smile
    Regarding the Beolab 4500's;
    they also have a line-in phono socket (located between the Powerlink-sockets)
    for connection to a non-B&O pre-amplifier.
  • 11-28-2009 4:40 AM In reply to
    Thanks - You know what? I just realsied that about 5 minutes after hitting the post button... But thanks for the clarity...
    Any ideas on a suitable surround sound amp? What would be great is to find a pre-amp only component as I do not intend to use the passive amps...
  • 11-28-2009 4:56 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
    The DeToma X501 would do the trick, it has Powerlink sockets for each channel.
    However, that product is discontinued and hard to find.
    Next to that, it is a product from a few years ago, so specifications are not really up-to-date.
    I used it for some time, and was quite pleased with it, it integrated very well in that specific setup.
    (it basically offered surround sound in a older setup of MX7000 and Beosystem 4500 + Beolab 4500's)
  • 11-28-2009 9:19 AM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    Yamaha RX-V3900 or it's smaller brother RX-V1900
    Realy good AV Receiver,  excellent in- and outputs.
    It has normal line out (pre out) for every single channel, so you should be able to connect the Beolabs!
    You can  buy it in 2 colors (black or titan).
