1st March February 2012
Latest post 11-20-2009 10:31 PM by jk1002. 6 replies.
11-19-2009 10:06 AM
kruppking
- Joined on 04-18-2007
- Teesside
- Posts 62
anyone used either?
I'm thinking of Archos at the moment through a BV8 linked to BL6000's.
not too bothered about streaming. However does anyone know if you can use the Archos remote whilst the main unit is hidden away?
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Re: Apple TV vs Archos TV+
Sorry, no idea - but I suggest to take a look at the Popcorn Hour. This should be in the PUC list.
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
jk1002
- Joined on 04-16-2007
- Boston USA
- Posts 1,620
I kind of agree, PS3, ATV or popcorn .... somthing like that ... while would you introduce Archos if the BV can control the earlier ?
kruppking
- Teesside
- Posts 62
Do you mean that Apple TV can be controlled through the BV using Beo4 /5 ?
If thats the case, then its a no brainer
Affineur
- Joined on 04-27-2008
- United States
- Posts 90
Yes, ATV can be controlled by Beo4/5. I have a similar set-up to what you are considering: BV8, ATV, Tivo, BL3s. Everything is controlled through a Beo4 via the BV8 ir blasters and all boxes are hidden from view. Very clean.
Seek simplicity and distrust it. Alfred North Whitehead
jk1002
- Boston USA
- Posts 1,620
Hello B&O in Denmark. Obviously you are not advertising the merits of the STB concept enough.
jk1002
- Boston USA
- Posts 1,620
Page 1 of 1 (7 items)
