Asud,
With all due respect your kinda vague - it is very difficult to imagine exactly what you have done and what the ultimate output it is that you are recieving in terms of music structure, tags, pictures etc... that you do not like.
I have assumed that you have ripped 20 CD's in your PC and transferred them to the BM5 "Music" directory?
If that is so, then start up Beoplayer in your PC and connect a "link" from your PC to the BM5. You may have to double click the B&O icon in the sys tray...connect to Beosound 5. It should turn from black to red.
Do a scan (N.Music / Setup / Scan Options / select BM5 drive + select Editing PC drive).
Once the scan is complete, the Lefthand side of your PC, Beoplayer should pull all the music files together. You should have a combined symbol of a black circle over a white outlined rectangle. This shows both the files on the PC and the BM5 are syncronised.
If you like what you see here, the BS5 should look OK.
Next, check the BS5. Has is sorted albums/titles/artists/covers the way you like?
If not, I suggest you go into Windows Media Player 10 or 11 (I assume you have this - not itunes) and edit all the tags as you see fit. I find simplifying the structure works best for me (I'll send some screen shots later tonight).
Hope that works.
10%
