Latest post 11-04-2009 5:16 PM by 9 LEE. 1 replies.
Page 1 of 1 (2 items)
  • 11-04-2009 3:07 PM
    • madskp
    • Top 500 Contributor
    • Joined on 11-06-2007
    • Denmark
    • Posts 111
    • Gold Member
    Beosound Centry not reacting to source buttons
    My Beosound Centry has started acting a little wierd lately. The source buttons are not working properly. When i try to start it using CD, Tape or Radio nothing happens. The aux button works though. When I use a remote i can choose a source without problems but the 3 source buttons will still not work. Once in a while though when i start it with the remote afterwards the source buttons will work.
    Anyone heard about or had this problem before, and is there any chance there is a solution for it?
    Thanks in advance
    Filed under:
  • 11-04-2009 5:16 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Re: Beosound Centry not reacting to source buttons
    Well, it's not going to be an option issue as it doesn't have Masterlink - so i can only guess the keypad is faulty?
    Sounds like an engineer job to me.. sorry Sad
    Lee
