Groan or hum….. I suppose it hums, so I stand corrected.
By the way you are NOT interfering as we all appreciate input on this site. How else are we to learn?
I am going to try lubricating the bearing to see if that helps. In any case, it is not a big issue.
I don’t know why anyone would put down the 8000 series Beograms as they are excellent turntables by ANY standard I know.
Mine is a total ***, sort of a Beogram Frankenstein. My original failed to perform and I was convinced (incorrectly) that it was the power supply. I misguidedly attempted to open up the 8000 from the back, managing only to break the plastic tabs. (Beyond stupid)
I then took it to a shop that assured me they knew how to repair it; they didn’t, and returned it to me in pieces.
Two more repair shops and the 8000 was basically toast.
My good B&O buddy from California offered me a tattered, but marginally functional 8000, so I used its back panel which had all the tabs in tact and the mechanicals with my pristine shell and dust cover.
The combined 8000 functioned for several months before developing a smoking problem. This issue was corrected by Martin who rebuilt the motherboard.
So now I have a completely functional 8000 with a MMC 6000 that has as you said the bass is exaggerated, but with my 120.2 speakers, the extra bass is more than welcome. In fact I think the bass sounds wonderful….. but the highs are well, just not stellar.
If I want highs I choose the Beogram 8002 with its MMC2 cartridge.
Having “survived” the disco era my hearing is marginal at best, however I still find the 102.2 speakers a bit too crisp in the high end for my taste. Hence my fondness for the big McIntosh ML-2 speakers which have super bass with 4 12” speakers, decent mid-range with 8” mid-range speakers, and an assortment of three tweeters that somehow never were all that good at the high end.
I especially like the combination of the McIntosh speakers with the Linn Isobarics which add the missing highs the Macs just don’t have.
So after all is said and done, the Beogram 8002/MMC2 is overall my best sounding turntable. Take that those who would put down these fine turntables!
Still, reverting to Peter’s words, my favourite turntable is the Beogram 4000 which trounced all others until the arrival of the MMC2. The MMC20CL, which I now believe was in the Beogram 8000 has recently suffered a hardening of the suspension.
When I feel like spending some real cash, I think I will try having my 3 MMC20CL’s and the MMC6000 rebuilt in Germany. I understand that the results are stunning and the case will be silver B&O stock, not the black of Soundsmiths.
Jeff
