I have the following setup, so far:
iMac which is linked to a routermodem which connects to my LAN. The LAN has a socket also near the BV8 and the BS3200.
Now I want to use a BEOPORT wo have my music from the MAC also on the BS3200. And since I already have an ethernet wiring I want to use this one instead of wiring a new Masterlink (quite difficult). I read something about ML to Ethernet conjunction but did not find a easy description and if I can buy.
Does anyone of you have an idea how the linking has to be connected? Which Equipment do I need?
Thanks a lot for your help,
Heribert
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
