Hello i am a newbie, and a novice
just unboxed my beosound 3200 after 4 years in storage, and it asks for a pin
all i get from the dipaly is WAIT
any help out there on a sunday evening?
Do as you are told, leave it plugged in and eventually the display will read PIN?
Then enter the PIN that you used when you originally installed the 3200.
Regards Graham
thanks joeyboy, but i cannot remember the pin from 4 years ago, any other way or is it contact the dealer monday?
Contact the dealer. There's no other way (that's why it was made).He will ask for proof of purchase so bring that along.
When you find the PIN I suggest that you look in the instruction manual for details of how you disable it!!
It will inevitably cause you trouble in the future.
