Latest post 11-17-2010 5:45 AM by Agent00soul. 0 replies.
Page 1 of 1 (1 items)
  • 11-17-2010 5:45 AM
    Lamps for Beomaster 901 (and others)
    I recently bought a Beomaster 901 for next to nothing and after investigation I found the following faults:
    Tuning lamps burnt out
    One rubber foot missing
    Minor scratches on the front panel.
    The light bulbs for the tuning indicator are so-called wedge lamps of the type W2x4.6d 12-15 volts 30 mA. Note that the bulb for the stereo indicator looks identical but isn't. It is a W2x4.6d 12-15 volts too, but it is rated 80 mA or 1 W. Both types are readily available and inexpensive (buy a bag of ten each!).
    Similar rubber feets are also available. Mine were circa 1 mm taller, so I replaced all four.
    I have now tested all functions and everything seems to work as it should and sound good. The potentioneters are all totally scratch-free, which amazes me.
