Hi all,
I recently acquired a BV7 and noticed that it does not change automatically to Zoom (Format 2) when needed. I just compared this with the dealers MKIII and it does change to Format 2 when there are black spaces on top and bottom. My BV7 does recognize the 16:9 (Format 3) and switches automatically.
I am only using Digital TV signal... it could be that the new HD tuner is not programed properly.
Blu-Ray, AppleTV and other sources are properly set by the BV7.
Does anybody know if this is normal, will there be a firmware update soon to correct the problem?
Thanks,
D.
