Thanks for a quick answer.... Supermartin!
Now the deck works again... Not even unplugged the thing. Bad solder then?
The platter rotates easily... and goes on for ages! All caps changed, including the one inside the processor block and the one underneath.
Is the humming sound on startup (and when it brakes to a stop) normal anyway?
