can't figure this one out...
after a certain amount of time (maybe 3/4 through a record), i am getting a slight buzz through both speakers. it will continue after the record stops. if i switch to "tape" or tuner on the receiver (a beomaster 2400) the buzzing goes away, only to return when switched back to phono.
the problem is exasperated (dramatically) when i touch the arm, or the cartridge, or wobble the platter.
i just bought a brand new cartridge, (in the hope that it would alleviate the problem), but still... the dreaded buzz.
any ideas?
thanks kindly.
