Latest post 09-10-2009 10:02 AM by Premiumverum. 1 replies.
Page 1 of 1 (2 items)
  • 09-04-2009 5:08 AM
    • heptan
    • Not Ranked
    • Joined on 09-04-2009
    • Posts 1
    Beolab Penta 1 revision
    Hi B&O guys
    I recently got a pair of Beolab Penta 1 with integrated Amplifiers.
    One of them went into off state (red led) while i was testing them.
    so i thought i will check all connections, see if the switches are ok und when i am already at it, replace the capacitors...
    i already found this thread: http://forum.beoworld.org/forums/t/5850.aspx?PageIndex=1
    but maybe someone can help, where to start. should i replace all caps? including the two of the power supply? what about replacing the opamps? what makes most sense?
    thanks in advance...
  • 09-10-2009 10:02 AM In reply to
    Re: Beolab Penta 1 revision
    All the answers you need seem to be in that thread!
    With old stuff like pentas replacing the electrolytic caps is always a good idea, especially those in the power supply (contact member Dillen! He sells good cap kits). Those in the crossover can be replaced by ordinary electrolytics or film capacitors for crossovers (don't buy expensive 'audiphile' film caps, cheaper ones like Intertechnik will do just fine) for a bit better quality.
    For the rest, adjust to your taste, the thread you found is most useful for that.
