Hi everyone.
Instead of continuing on a thread with plenty of different issues, I decided to make a separate post for this pretty significant issue.
My dealer is a good man, and was nothing but understanding when I adressed the MK IV 50 HZ output issue. For those new to the case: The new Beovision 7-40 MK IV has a 100/120HZ panel, but when watching TV its menu displays that the panel output is 50HZ (should be 100), and when watching BluRay it says 48HZ (should be 96).
My dealer then checked his display model, and it had the same bug. As it turns out, probably every single set has this bug.
Answer from BnO: The Beovision 7 has a 100HZ panel, and would not even be able to display a 50 HZ picture. A 50HZ inputsignal will be enhanced to 100HZ output. The fact that the menu displays 50HZ is wrongful information. The signal IS in fact displaying 100HZ. The latest software upgrade (already out) adresses this issue.
So - one less thing to worry about....
BV 7-55, BL 7-4, BL 9's, BL 4's, BL 3's, BC 2300, Beo5, Beo4
