Hey,
I've noticed in pictures and diagrams that when the 3's are mounted on the tall stand, they angle upwards very slightly. The shorter stand does not seem to do that:
The situation in my apartment is such that if I were to get them, the best solution would be for one side to be on the tall column, and the other to be on the short. Are the speaker mounts adjustable so they can both rest at the same angle?
Thanks, Leo
BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
