Gentlemen, Please may I request some words of wisdom. I've had a B&O 6500 system ( Tuner/amp, CD, Tape, Phono ) since they came onto the market. In a moment of madness I decided to replace the Tuner/amp with a 7000 model, for no other reason than it was not quite so old and had some minor improvements. I hoped that this would be a simple unplug, replace exercise but this was not to be. I now find that the units do not communicate with each other as they should. I can use the remote ( 5000 ) with the tuner but nothing else. The tape works independently but not through the remote and does not record from the tuner. The CD does not work period, requesting a CD which it has. The whole system has become a shambles and was working perfectly well before. ( Why have I done this ? )
I feel this is a setup problem rather than a hardware failure, but having trawled the forum I have not found an obvious solution. Would someone please point me to a reference as to how to correct the problem or suggest a remedy. ( I know, leave well alone ! )
Many thanks
Paean
