Hi all,
I recently bought a VX5000 from ebay and, even thought that it shouldn't work, I've tryed
to connect it to my MX3000. Guess what? The VX5000 works perfectly in all its functions!! (advanced PIP functions too!!!).
Obviously the channels dump doesn't.
So why B&O 'Config guide' SW says that the PIP functions should not work? (see below)
************************* VIDEO SYSTEM SETUP **************************
Beovision MX 3000
Beocord VX 5000 (VR 1)
Connection Video
Connect the VR 1 to the TV-set using a fully specified 21/21-pin
A/V cable (RGB cable).
Connect the aerial to the aerial input of the VR 1.
Connect the aerial output of the VR 1 to the aerial input of the
TV-set using a coaxial cable.
Selecting option on the TV-set
Option: OPTION 1.5 (Factory setting)
Press: STANDBY PICTURE 1 STORE
PICTURE 5 STORE
If option programming is made using Beolink 1000 MK3/MK4 or MK5 press
LINK before the sequence PICTURE x STORE
Note!
The Beovision must be equipped with software (S/W) 2.1 or
higher, part no. 8341297. OK... It is.
The TV must be equipped with a Teletext module. OK... It has.
It is not possible to use the digital functions (PIP etc.)
in Beocord VX 5000.
my MX3000 type is 3144 SW 2.1
VX5000 type is 4539 SW 2.1
Is the MX3000 SW 2.1 (part no. 8341297) the same of MX5000 one?
thanks,
onyx
