Hi Guys,
I got a link problem, My avant which is the slave has started to play up, the stand by led is flashing quite fast. I have tried usual things like resetting etc, I can access the CD/Radio from the Beomaster 7000 from both the master (Beosystem 2) & the avant, but I cannot access the sources on the master like DVD etc, the whole system seems to freeze. I have reset the options & have checked the cables.
Here are the error messages from both of them
Avant (slave)
Clock error Comm, fail- there are no tv or ML/SL errors
BS2 (Master)
Last Tv errror 0406 22-2A
Last ML/SL error TD
Hope someone has got an idea.
Also is it possible to use an AV2 Expander with the Beosystem 2 to provide more inputs mainly for games consoles.
Thanks in advance
Simon
