Hi Guy,
glad you got them,
i take it you mean it has the 4 floor stand lugs still on the unit ?, a philips head or allan key will remove them,
pack some bubble wrap inbetween the glass before you turn the machine over onto its front so you dont put any excess pressure on the glass.
place the 4 spacers over the 4 holes, place the bracket over the spacers and screw them in, job done
when attaching the smaller long thin bracket section to the wall, borrow a small child to hang off it making sure the wall screws will hold your bs9000, dont forget to put 6 cds in the childs pocket
