jbaunsoe:
Thank you, but...Any specific RIAA pre amp you can recommend? Sorry to ask - I'm a rookie in this subject :)
/Jesper
They are available from £10 to thousands! Just what the difference is I don't know and probably can't hear anyway. I suggest you google or look at amazon and see what you fancy. There used to be one called the "Discsaver" but as far as I know it is no longer made.
One of the Beoworld sponsors, Soundsheavenly, can supply a reasonable one complete with leads to suit. His advert is at the bottom of this page.
