Hello
First contact help demand
Backed to good taste. I looked my Beogram 1000, type 55203 turntable after many years stored I want enjoy it again; it's first time I opened it but steps are good
1-I bought by downloading the only service manual I find (for Beogram 1000 type 5229); thereis any concerning type 5203? if so how to get it?
2- I got: Belt cuted shorter and fitted again. Arm balancing slider pos.2 line.Arm height adjustment. Motor shaft oiled(quite silence running).selector and fine speed control oiled. strboscopic 33 rpm ok with fine control
3- Device is fitted with SP10 cartridge (no SP7 or 14)I remember working nice, but now no more
When I was setting all this the arm came out rest and stylus touched any point, resulting support diamond bent down and I checked also twisted, I tried to correct, even rotating socket in arm but not enough.
Magnifier glass shows diamond support turned to left and no way correcting with pincers wich marks and risk damage
I tested with a LP but sound is bad, rumble noise and stylus keeps on same tracking no feeding to centre
Solution?
New stylus? where?
I tried to pull shell cartridge off (loosen screw) but no succeed afraid to damage. maybe I have to do it if buying a new stylus!!!
welcome your support and advice
thanks a lot
Fernando
