Latest post 04-28-2009 2:32 PM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 04-28-2009 10:56 AM
    AV9000 and HDR1
    Hi all,
    Does anyone know if my AV9000 (SW 1.2) will be able to use one of my HDR1's?
    They aren't together at the moment so I can't just plug it in to check!
    Cheers
    GUY
    Train Hard - Run Fast - Hit to Kill!!!
    Filed under:
  • 04-28-2009 2:32 PM In reply to
    Re: AV9000 and HDR1
    Possibly if used instead of the VCR. I think if you try to use both, you will hit problems.
