Latest post 04-18-2009 3:38 PM by Medogsfat. 9 replies.
Page 1 of 1 (10 items)
  • 03-10-2009 3:55 PM
    • rebrof
    • Not Ranked
    • Joined on 03-09-2009
    • Posts 5
    beomaster 300
    hi  i have a beomaster 3000 had it form new 1985 ,now not working,when i press any of the touch buttons on the control panel the relay on the circuit board energises then drops out straight away . any ideas .thanks
    Filed under:
  • 03-10-2009 4:13 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beomaster 300
    Welcome to Beoworld ! Yes -  thumbs up
    Could be a shorted output. Have you tried with no speakers connected ?
  • 03-10-2009 4:24 PM In reply to
    • rebrof
    • Not Ranked
    • Posts 5
    Re: beomaster 300
    hi thanks for the reply have done but the problem remains thanks..ken.
  • 03-10-2009 4:49 PM In reply to
    • Dillen
    • Posts 5,008
    Re: beomaster 300
    It could be one of several things then.
    Most likely the output stage which, in your Beomaster, is one large (and fairly cheap) chip.
    If this is indeed the case, the repair shouldn't be too costly.
  • 03-20-2009 2:35 PM In reply to
    • rebrof
    • Not Ranked
    • Posts 5
    Re: beomaster 300
    looks like you may well be dead right with this one.anybody know of a supplier for the chip.regards ken.
  • 03-20-2009 5:03 PM In reply to
    Re: beomaster 300
    I replaced one in a Beomaster 2000 recently (should be the same one).
    Just search on eBay for "stk463" (or whatever type yours is). I replaced mine with a Stk465 that I paid 6€ for.
  • 03-20-2009 5:17 PM In reply to
    • Dillen
    • Posts 5,008
    Re: beomaster 300
    Can you replace it yourself ?
    If the chip in your Beomaster is a STK 463, I have one.
    Actually, the one I have is a STK 465 but that only means
    you will get 5 Watts more per channel. Yes -  thumbs up
    Edit: Oh yes, there are some available at Ebay. Make sure to get the correct physical outline.
  • 03-21-2009 4:27 PM In reply to
    • rebrof
    • Not Ranked
    • Posts 5
    Re: beomaster 300
    thanks for that there is indeed one for sale on ebay ..regards..ken
  • 04-18-2009 3:33 PM In reply to
    • rebrof
    • Not Ranked
    • Posts 5
    Re: beomaster 3000
    update  got myself the the stk power amplifier and with a bit soldering i now have a restored system. Thanks for members  assistance.
  • 04-18-2009 3:38 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Re: beomaster 3000
    Great stuff and worth a couple of hours work, glad it was such a straight forward fixSmile
    Chris.
