first try exchanging left/right and another plug/cable on your amplifier, just to make sure that no other part is defect.
If the Penta is the problem... sorry, then you need help from a service shop. Then it's probably a dead cap, bad solderings or a broken wire behind the flap.
Does the foot/amp become hot?
