Is there any potential harm in termporarily overrriding the firewall setting on Beomedia to let it update XP to SP3 and subsequent updates?
When I contacted US Beocare and asked why I couldn't view the new Beosound 5 website on my Beomedia, the first answer was "I think you should be able to see a B&O website on a B&O product designed to do so."
But whe they looked into it, I was subsequently told "No, you can't view this website on your Beomedia."
So I performed an update as above, and updated the Flash and Shockwave players by disabling the firewall for a short time.
Now, I *can* view the Beosound 5 website. That got me thinking about other possible updates to Beomedia.
Any Thoughts or ideas?
Barry
