Latest post 03-03-2009 3:39 PM by Keith Saunders. 4 replies.
Page 1 of 1 (5 items)
  • 03-03-2009 12:29 PM
    2nd of the Day - Avant PiP module - Type 4141 - Doesn't fit????
    Ok so while playing with my Avant today I tried to install a Picture in Picture module.
    Its a Type 4141 and according to the booklet should fit into my Type 84/23.
    It says it attaches to the PCB2 which is the video processing and teletext and then the ribbon cable connect to P35 on PCB2.
    All very easy except the board itself is too large to fit as per the single diagram (I have another look for a better manual on here).
    Also I can't seem to find P35 which should be about an inch across!
    Anyone have any ideas?
    Train Hard - Run Fast - Hit to Kill!!!
    Filed under:
  • 03-03-2009 1:12 PM In reply to
    • Gerd
    • Top 150 Contributor
    • Joined on 04-20-2007
    • Germany
    • Posts 523
    Re: 2nd of the Day - Avant PiP module - Type 4141 - Doesn't fit????
    PiP module for your Avant is 4165, not 4141!
  • 03-03-2009 2:13 PM In reply to
    I have an Avant Type 81/33, and would like a PIP module for it, do you know which one i need Gerd ?
    I am also after Pro Logic Surround module and STB-C
    thanks
    Peter
  • 03-03-2009 2:54 PM In reply to
    Hi Gerd,
    The paperwork says its for:
    1414100 - 50Hz
    1415100 - 100Hz (28")
    1416500 - 32"
    It looks like I have a Brand New PiP module for a 50Hz Avant then... :-(
    Oh well - any takers?
    NEW in box unused! - RRP = £170 = ouch!
  • 03-03-2009 3:39 PM In reply to
    Peter,
    If you want the PIP module for your AVANT 50 Hz (Mark I or Mark II) then you would need the one "Large48" has got namely a type 4141
    If you also want Dolby Surround Sound then that is type 4140 and the NICAM decoder is 4144
    Regards Keith....
