Latest post 02-20-2009 5:37 PM by chr_elling. 3 replies.
Page 1 of 1 (4 items)
  • 01-28-2009 10:22 AM
    • chr_elling
    • Not Ranked
    • Joined on 11-18-2008
    • Denmark, Gentofte
    • Posts 51
    beosound 3 stop respondingto commnands
    My other wise perfectly functioning Beousound 3 (radio shaped like amilk karton) stopped responding tomy commands.
    I have tried to remove battery and  dc suply in order to "reset" it, but is still does not work - I cannot activate the radio og get the antenna up.
    The problem occured after i programmed the timer functioning,
    Do you have any advice?
    Regards
    Christian
    B&O old school link nerd
  • 01-28-2009 2:37 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: beosound 3 stop respondingto commnands
    There was a problem with the control panels on the early versions of these, I would go back to your dealer telling him it is a known problem and if they are willing to replace it. If it is still under warranty they will do this in any case.
    Chris.
  • 01-30-2009 10:23 PM In reply to
    • chr_elling
    • Not Ranked
    • Denmark, Gentofte
    • Posts 51
    Dear Sir.
    Tank you for your advice.I did exactly what you recommended me. b&o is aware of the fault.There was 1 month left ofmy guarante. Otherwiseit would have been a £ 200 repair. But free for me.
    So once again. Thank you,
    Regards Christian
  • 02-20-2009 5:37 PM In reply to
    • chr_elling
    • Not Ranked
    • Denmark, Gentofte
    • Posts 51
    Dear Sir!
    I had 30 days left of my warrenty. Otherwise I would have been confronted with a bill half the size of product from new it eslf.
    So thank you for your brilliant advice  - that is goíng to the place where I bought it.
    It i presently  placed in our bath /shoer room - do you know if is moist sensitivr?
    Thank you in advance for brilliant  advice.
    Kind regards
    Christian
