If I use the tape deck in my Beocenter 7002, everything works fine for a few minutes, and then the Beocenter resets. The effect is as though the power has been turned off and then back on - even the clock gets reset.
When this happens, the area at the back of the unit where the voltage reguulator ICs are located appears to be hotter than normal.
Some questions:
  1. Is this a known fault on these machines, or do I have to experiment?
  2. Is the problem more likely to be the tape drive using too much power, or the power supply having deteriorated?
Thank you for your thoughts,
Mark
