Hi all
I have a ML/MCL Converter and an IR eye which I do not currently use. Now I am looking for a solution to use the converter as amplifier for some passive speakers. This is meant to be a stand alone solution - no link to any B&O system required. Unfortunately there is no way to switch the converter on
Is there a way to connect an iPod to the converter by using an adaptor? How can I use the setup without the need to knock something together?
Does anyone have an idea?
Rob
