hello all,
i'm blown away by the quick responses. this piece of equipment illicits such an emotional response from all who see it. we just had a new years eve party, and many people asked questions about it. i was forcd to use the right side only, sending the output from speaker one to one channel, and that from speaker two to the other. both left side speaker outputs do not work. bummer!
i'd like to try the test switch idea. however, i cannot locate it. is it inside the unit? also, how do i obtain a service manual? i like doing my own repairs when i can. it's also interesting to understand the signal flow.
is there a trick to getting the bottom off without cracking the pc board that houses the remote sensor? i did a nice job cracking that right off the board. i'll glue it and hardwire it.
thanks again,
peter
p.s. which redline speaker sounds best?
