        1st March February 2012
	    Latest post 05-28-2007 5:15 PM by  Craig. 12 replies.
								        04-19-2007 1:21 PM
									        Stupot
								                - Joined on 04-19-2007
								                - Posts 8
										    help please, replacement battery for Beocom 4
										    Hi all,
 Does anyone know where I can source a new battery for my Beocom 4 from?
 My dealer has suggested that I return it to them to be sent off for repair, no doubt at an extortionate price.  Apparently, the battery is a non user serviceable part.  Despite the fact I am more than capable of removing the cover, and unplugging the battery, its hardly rocket science. Come on B&O, I love the phone, dont let me down with the service.
 Over the last couple of days, the phone has started displaying the message "CHARGE BATTERY" despite the fact that its been charged.  Its about 3 years old and has seen normal use.
 Would be grateful for any advice, or help.
 Stuart.
									        Keith Saunders
								                - Joined on 04-16-2007
								                - Technical Advisor, Little Ann, Hampshire, UK
								                - Posts 3,810
										    Re: help please, replacement battery for Beocom 4
										    Stuart, Well actually, the problem may not be the battery. In the earlier versions apparantly there was an intermittent fault in the software that measures the battery capacity. The software believes the charge is lower than it actually is. A new software version was implemented in December 2003 to take it to version 1.7 which solved the problem. This maybe your problem. Keith..
									        Craig
								                - Joined on 03-29-2007
								                - Costa Del St Evenage
								                - Posts 4,855
										     There is one one Ebay at the moment on a Buy It Now.
      http://cgi.ebay.co.uk/Genuine-Bang-Olufsen-B-O-Beocom-4-Battery-2-4V_W0QQitemZ330111072514QQihZ014QQcategoryZ86805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem    Craig
									    For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
									        Craig
								                - Posts 4,855
										    Damn too slow.   Craig
									        Stupot
								                - Posts 8
										    Wow guys, talk about a quick service.  I'll be sure to check them out.
									        Stupot
								                - Posts 8
										    @ Keith,
 I guess the Software update has to be performed by the dealer?
 Stuart
									        Keith Saunders
								                - Posts 3,810
										    Stuart, Yes this is a dealer job, they have to download the software update, so its not a chip change. You could check to see what software version you have at present by going into the service menu. Almost all B&O products have some sort of service menu. I think you need to press 9 - #  - 9 - #  - 9 - * - /// You will get handset software version, then Base software version followed by Display contrast, delete phonebook, user default, serial number, IPEI number and production date. Keith..
									        Stupot
								                - Posts 8
										    Guys, just to say thanks v much.  You all rock.
 I had searched ebay looking for that battery and come up blank. Dont know what I was doing wrong, but your assistance really is much appreciated.
 Keith, right now I cant even keep the phone on for long enough to enter that code, which makes me lean towards it being a battery problem.  I take your point about the software telling it to shut down though, so if the new battery doesnt work, it will be going back to the dealer.  At least I'll only be 9 quid down (until I get their bill...)
 This is the second time I've used this forum, and the second time I've got quick practical advice.  Thank you all again so much.
 Stuart.
									        Craig
								                - Posts 4,855
										      Stupot:Guys, just to say thanks v much.  You all rock. This is the second time I've used this forum, and the second time I've got quick practical advice.  Thank you all again so much.
 Stuart.
   Thats what we are here for.    Craig
									        Stupot
								                - Posts 8
										    Hi all,
 Despite your expert advice, the phone is still not right.  I got the new battery from eBay yesterday, fitted it and left it turned off and charging overnight.  I came home from work today, and  turned it on.  After thirty mins, the red light is flashing again, and the information says CHARGE BATTERY.
 Super annoying, but I'm glad I'm not too badly out of pocket.
 Unless anyone has any more words of wisdom, its back to the dealer for me.
 btw Keith, I couldnt get that code thing to work.  not sure about some of the buttons you wrote.  I dont suppose it matters terribly anyway as it might diagnose a problem but not fix it.
 Thanks again
 Stuart
									        Stupot
								                - Posts 8
										    Just for those that might be interested in this in the future, I finally got round to taking the Beocom 4 to the dealers for fixing.  It transpires there was a problem with the PCB, and a replacement will be about £70.00.
 Thanks again to those who replied.
									        Craig
								                - Posts 4,855
										    Glad you got it sorted in the end.   Craig
        Page 1 of 1 (13 items)
