The buttons on my BM 1700 have gone faulty. They work, that is, switch the unit on but they won't stay on. Volume, Balance, Bass, Treble work as they should but all the others won't stay in place. You have to hold the button down to listen.
Any help would be appreciated as a friend of mine has been using it and is now quite disappointed not to have it working!
Ben
