Hallo Folks,
My Beolink PC2 worked for some years. But now I screwed the connection up.
I have following Problem now. Tried to install everything new.
1) Downloaded Beo Port 4.83 (USB is not connected)
2) Then I came to the point where it says
- connect the Beo Port box to the mains
- connect the USB cable between your PC and Beo Port
contiues automatically when the above instruction has been performed
3) But nothing happens then. Looks like I have screwed something up
