I have just purchased a rather nice Ovuerture Stereo with the matching 2500 Active speakers if any kind soul can answer these questions Id appreciate it
looking in the instruction manual it shows that the Stero can be connected with three leads using th same current these are Female and male ( what I call tape lead connectors ) mine just has three tape leads with three seperate plugs one for the main unit and one each for the Speakers
Were can I get these leads from ie. two of the female to male leads
My second question is
How do you remove the speaker Grills ( I aint got a clue ) and likewise for the glass panels to clean behind, im frighterned of smashing the glass pulling to hard , so have yet to attempt it
And FInally is there a supplier who makes an aluminium insert to cover over the tape recorder bit as I dont use it
Oh I forgot " Is it possible to turn the lights off to save energy
Cheers Eddy
