Latest post 05-23-2007 4:25 PM by Jandyt. 14 replies.
Page 1 of 1 (15 items)
  • 05-23-2007 3:56 AM
    BeoVision 7 cleaning the AR screen
    Has somebody any experience with cleaning the screen on BV7? I have a lot of troubles with cleaning it. Is it possible to buy some special solution for cleaning the AR screens?
  • 05-23-2007 4:24 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    Re: BeoVision 7 cleaning the AR screen
    avus17:
    Dead easy - just wet some paper towel, wipe clean. Take some dry paper towel and quickly dry.
  • 05-23-2007 4:46 AM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    We use 50% diluted good quality vehicle screenwash along with Kitchen Roll.
    Works perfectly every time!
    Lee
  • 05-23-2007 4:51 AM In reply to
    When we were visiting the Struer factory, I asked the guy who was looking at the production of the BV7 screens.
    He said NO ALCOHOL, or max 5%.
    He recommended to use very diluted washing up liquid.
  • 05-23-2007 10:17 AM In reply to
    • Tom
    • Joined on 04-16-2007
    • Luxembourg
    • Posts 3,175
    moxxey:
    that's how I do it too. but I use paper towel with only a few drops of whater and rub until the screan is clear. works very well
    Music washes away from the soul the dust of everyday life. - Berthold Auerbach
  • 05-23-2007 12:36 PM In reply to
    i use 1 damp e-cloth using only water, then buff it off with a dry e-cloth, it stays smear free for ages
    its a specially textured cloth that needs no chemicals whatsoever no matter how diluted,  i use them on everything, and for glass they are perfect
    jay
    jason
  • 05-23-2007 12:38 PM In reply to
    • beodim
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Switzerland
    • Posts 130
    jay:
    jay
    What is e-cloth? Sorry for my ignorance.
    BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
  • 05-23-2007 12:42 PM In reply to
    heres a link
    http://www.enviroproducts.co.uk/index.asp?aid=14
    i looked foe ages for something that would clean kitchen worktop granite smear free and came across these
    jay
    if only they did one with the beoworld logo onWink
    jason
  • 05-23-2007 2:11 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    jay:
    jay
    I think I'll give these a try and order some. There are different ones.Which one(s) do you use?
  • 05-23-2007 2:25 PM In reply to
    • 9 LEE
    • Moderator - UK
    • Posts 5,223
    In our defence, you lot probably keep your screens a lot cleaner than most people..
    When you get a screen in that's been licked by household pets, prodded with biscuits by unruly children, then prodded by customers greasy fingers - kitchen roll just doesn't do the job!
    Lee
    Laughing
  • 05-23-2007 3:40 PM In reply to
    tom:
    jay:
    jay
    There are 2 types, a normal one for everything and a finer one for glass, although IMHO there is no difference so i never bother using the glass one, ideally you need 2 normal e-cloths, one to use damp and the other to buff with, thats where the different colours are useful.
    let me know what you think when you try them
    jason
  • 05-23-2007 3:42 PM In reply to
    • Tom
    • Luxembourg
    • Posts 3,175
    jay:
    Hey Lee, wouldn't e-cloths be a good merchandising idea to expand our (your) Beoworld Gifts? Geeked
  • 05-23-2007 3:49 PM In reply to
    9 LEE:
    Lee
    Laughing
    that reminded me of what my beocom 2 when through to get my avatar
    licks, biscuits then prodsLaughing
    jason
  • 05-23-2007 3:53 PM In reply to
    tom:
    jay:
    Hey Lee, wouldn't e-cloths be a good merchandising idea to expan our (your) Beoworld Gifts? Geeked
    exactlyBig Smile
    ill order 6
    jason
  • 05-23-2007 4:25 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    I always use damp kitchen roll followed by dry kitchen roll. I do remember the guy in Struer saying NO ALCOHOL!
    Andy T.
    Poor me, never win owt!
